Electroforming question
Is anyone familiar with electroforming on an interior cavity. I have had experience where we electroform over an aluminum mandrel, then acid remove the aluminum when finished. Is there a process that does the opposite of this. For instance if there were a two part mold with the cavity in the middle of the mold (like an injection molded plastic part), however you electroform copper on this inside surface of the mold, and then just pull the two part mold apart, and you have your thin, electroformed part without having anything on the inside that needs to be etched out. Could a part even release from this mold faces.
RE: Electroforming question
Mike Halloran
Pembroke Pines, FL, USA
They have a website, perhaps you'll find it there.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Yes. Something like that. On one half of the mold it would be possible to have a hole and have the electrode go in and also allow electrolyte to be in there. Seems like there is someone that has done this. I am still looking. Thanks
You are looking for a method to produce higher volumes at lower cost, correct? How thin of a shell are you looking to form? Is mechanical forming/drawing from foil a possibility? Just a couple of thoughts.
Reference:
Bocking, C. and Jacobson, D.M and Rennie, A.E.W (2002) Rapid production of microwave packaging in Silicon Aluminium by thin-shell electroforming. Microelectronics International, 19 (1). pp. 30-32. ISSN 13565362
