output coupler
output coupler
I am curious if there are any specific signs a output coupler is going bad or needs replacement. I am quite sure the one i have in use now is at least five years old and could probably be changed.
RE: output coupler
To check it, you can take a cold and hot mode. If the hot mode is getting a lot deeper and diameter getting a lot smaller compared to cold mode, then the output coupler is stressed and needs to be replaced.
RE: output coupler
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
RE: output coupler
