nx 8 hole table problem
RE: nx 8 hole table problem
I just tested this using NX 8.0.1.5 and it worked fine.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
Please send a pic of your menu and the procedure you follow.
Thank you.
work fine for me to and my hole table dialog looks exactly the same as the image posted.
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.6, NX6.0.5, NX7.0.1, NX7.5.0-> NX7.5.5 & NX8.0.0 -> NX8.0.1
thank you!!
there most be something wrong my with lic or something cause it will pick the point, select the circles (or view) and then drop the orgin... hit ok and NO table in the drawing. NO CLUE.
Could it be that the table output was made on an invisible layer?
2x NX8.0.1.5 Mach Design
1x Solid Edge ST2
GOT IT!
If you open a file thru convertion (i.e. step, igs, ect.) the file sometimes creates its holes has a feature not a single hole thus the table see's no holes for the table.
Thank you for your help.
UPDATE:
Come to find out that the hole table problem with the converted files was a NX 8.0.0 problem that GTAC knew about. They corrected it in update NX 8.0.1
NX 8.0.1.5 is available for download so let's get going, eh?
John R. Baker, P.E.
Industry Sector
Cypress, CA
