Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I also believe that we all can contribute to each other's growth by sharing knowlege and experiences. I would love to take my skills and help people around the world solve problems..."
Geography
doginabag (Civil/Environmental)
15 Feb 12 12:53
I am wanting to use an electro magnet much like this to hold a 60mm diameter steel spere for use in a test rig.
http://uk.rs-online.com/web/p/holding-magnets-solenoid-accessories/0346081/
I previously bought another magnet that was rated to carry 2.5 kg.
The steel sphere weight approx 1.1kg, but because of it being spherical and not fully contacting the face of the magnet, it was barely able to hold it.
So my thinking is to use a larger magnet with a greater holding force to overcome the inefficient contact area.
However a largewr diameter magnet means that the outer case of will be further from the sphere, only the inner core will be in contact.  Is this ok or will it cause me problems?
Thanks.
dgallup (Automotive)
15 Feb 12 12:59
Why not make a cup shaped pole piece to increase the contact with the magnet you have?
EdStainless (Materials)
15 Feb 12 17:13
That is the key, a cup shaped pole piece.
You could just about any pole piece configuration as long as you machined the surface with the spherical contact shape.
Plymouth Tube
Close Box
Join Eng-Tips® Today!
Join Us             Close
