NX 6.0 & VRML export of assembly
is there a specific workflow for exporting large assemblies in VRML format? I've tried using both VRML 1.0 and 2.0 but only get some parts through.
Thanks!
Thanks!
RE: NX 6.0 & VRML export of assembly
I think this is the first VRML question that I've heard anyone ask in at least 10 years or so.
Anyway, I opened an assembly with 148 components and performed an Export using the VRML 2.0 formate. I was then able to open it in the only VRML viewer that I have on my system, FreeWRL Launcher (version 1.22.12). It seemed to open OK.
However, I was not able to open a VRML 1.0 formatted file.
Note that this testing was done using both NX 7.5.5.4 and NX 8.0.1.5.
So as far as I can tell, at least up to around 150 components the 2.0 option works. Perhaps you should follow-up with GTAC and see if they can help you.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
I think this might be NX 6.0 issue. I tried changing reference sets etc but none of that worked.
Thanks for trying out this situation.
John R. Baker, P.E.
Industry Sector
Cypress, CA
John R. Baker, P.E.
Industry Sector
Cypress, CA
