NX 7.5 define geometric tolerance with extension lines
Does anyone know if it is possible to use extension lines with a geometric tolerance definition in NX on its own without attaching it to a dimension? Thank you.
Raymond
Raymond
RE: NX 7.5 define geometric tolerance with extension lines
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
The same thing applies when you use the "finish symbol" menu.
Jerry: I tried using a flag but it only has one side of the extension line.
It is supposed to look like the one drawn in the attached picture.
Thank you again.
John R. Baker, P.E.
Industry Sector
Cypress, CA
John: I tried accessing it at home and I can see it. As indicated in the picture that I posted I need something with two extension lines. Jerry already said that it is not supported in NX.
Thank you both for helping.
