EFFECTIVE FLANGE WIDTH
how does AASHTO provide for the effective flange width of a steel beam or girder bridge that does not have the required effective flange width along the outside coping beam? Can a designer still use the total effective flange width even if it is not centered on the beam? Is it the designer's responsibility to make sure that this width is provided at the outside coping? Has anyone seen a girder described in AASHTO 10.38.3.2 having only a flange on one side and where would a designer use such a section?
RE: EFFECTIVE FLANGE WIDTH
curvbridger
