HEC-HMS Reservoir
HEC-HMS Reservoir
Hello again,
i got the problem that i want to use a reservoir to catch some a part of the flood (in german: Hochwasserrückhaltebecken ;)). The thing is, that the volume of the reservoir is really small, so HEC-HMS end most of the simulation runs because:
"ERROR 41346: Computed storage in reservoir "HRB_1_TEST" exceeded maximum value in storage table"
Okay, from this i know the maximum rainfall-time witch the reservoir can handle. But is there any possibility to work on with the reservoir and rainfall-times, greater then that witch are to handle, and a constant maximum discharge without creating a dam break?
The other point ist, that i can not really work with a constant discharge. I mean, that e want a constant discharge from 1,7 m³/s independent from the elevation.
I use the Elevation-Area and the Elevation-Discharge function. Method is Outflow Curve, Storage Method: Elevation-Area-Discharge, Primary: Elevation-Discharge, Initial Condition: Inflow=Outflow
Best regards
Best regards
RE: HEC-HMS Reservoir
Computed pool elevation is above maximum table value for reservoir "HRB_Test".
Why must i choose a elevation under the maximum high of the water?
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
Peter Smart
HydroCAD Software
www.hydrocad.net
Thanks and best regards
Elevation Storage Area Discharge
412.70 0.000000 0.000000 0.00
412.80 0.001803 0.039116 1.40
412.90 0.009839 0.132953 1.98
413.00 0.029924 0.282936 2.42
413.10 0.068552 0.490934 2.80
413.20 0.127160 0.687006 3.01
413.30 0.209226 0.968337 3.43
413.40 0.322507 1.317260 3.70
413.50 0.477253 1.749064 3.96
413.60 0.673533 2.158241 4.20
413.70 0.908421 2.552598 4.43
413.80 1.189736 3.087467 4.64
413.90 1.537613 3.773121 4.85
