Boost converter producing exactly 1/2 expected voltage
Hi all,
I'm an experienced software engineer designing my first commercial hardware device (we're a startup with no money to hire a real EE). It's a battery-powered sensor using the TI TPS61025 synchronous boost converter to provide a fixed 3.3V output. I designed and built it according to TI's spec sheet ( http://www.ti.com/lit/ds/symlink/tps61020.pdf). But it's producing 1.6V, exactly 1/2 of what I expected. I cannot guess why. Can anyone give me a clue about how to go about "debugging" this? The QFN package was of course particularly challenging to solder, so I'm wondering if a screwup in soldering could produce this rather curious result.
-Russ
P.S. If there's an equivalently efficient device to do what the TPS61025 does in a non-QFN package, I'd love to know about it, because I've come to hate QFN.
-Russ
RE: Boost converter producing exactly 1/2 expected voltage
What voltage do you measure at the feedback pin?
Dan - Owner
http://www.Hi-TecDesigns.com
-Russ
I assume from your indication that you don't like QFN devices that you may be trying to use the chip using crude prototyping techniques.
Do not try to prototype a device like this with wire leads soldered to the chip and to a solderless plug-in type prototype board. Even at a few hundered kilohertz a couple inches of wire on a several uF capacitor will be enough inductance to make it like the capacitor isn't even there. Electrolytics have enough internal inductance (usually expressed partially in their ESR rating) to make them useless even with short leads.
If you are not using low lead inductance capacitors (i.e. ceramics) or have long leads, you could get the chip into a funky start/stop mode where it's not putting out the proper voltage. If you are prototyping using solder and a breadboard, I would recommend you use surface mount caps with very short leads soldered to them.
The first step is to ensure what you built is what you've intended to build. Use a multimeter in audible continuity mode to test that every point your schematic shows should be connected is in fact connected. If you want us to check your schematic, post it.
Then, to debug, you need to understand how a boost converter works, and you need an oscilloscope. The half voltage output is probably just coincidence. What is your input voltage? If it's a single battery cell, maybe you're actually seeing the input voltage?
Start by applying a fixed resistance for the load - this is the easiest load for the converter to supply. Something like a 10 Ohm resistor will give you a nice 330mA load current.
Then measure from GND to VOUT, from GND to SW and from VBAT to SW with a CRO. What you're looking for is evidence of the boost converter sawtooth wave. It's presence or absence should narrow down the problem.
Is the exactly 1/2 voltage significant, or just a random artifact?
What I'm especially hoping for is some approach for debugging this problem. I know how to deal with software, but hardware debugging is outside of my skill set.
-Russ
I can certainly post my schematic if my previous post is not sufficient (I use DipTrace; what output format is appropriate?).
I don't own an oscilloscope, only a logic analyzer. Is something like the DSO Nano oscilloscope V2 sufficient (and essential)? Will that help me detect soldering issues?
Thanks especially for the debugging process. I'll get right on that.
-Russ
TTFN
Dan - Owner
TTFN
Dan, what would you tighten for production layout? Would you move the capacitors even closer? What about the inductor?
As LightYear suggested, I verified all the connections are correct using my multimeter in audible continuity mode. And in doing so I noticed something that's definitely wrong: I have the tantalum capacitor backwards, with the stripe to ground instead of VOUT. D'oh! Could this be causing my problem? Can I just unsolder it (assuming I even can) and put it right, or might it have been damaged by being in backwards?
I've attached the relevant portion of my schematic.
-Russ
-Russ
And yes, it's probably not suitable. Those Kemet caps have very low ESR. A standard "low ESR" tantalum cap will have about 10 times as much ESR. Also check the frequency V capacitance of your chosen cap - if it rolls off significantly by 600kHz, it might not be suitable.
And yes, that cap is critical to operation - anything could happen if it's not working.
Since you're using a power supply to drive the input, I recommend a 0.1uF cap directly across the VBAT/GND pins (in parallel with your 10uF input cap). It probably wont be necessary if you're powering the device with a battery and you're in a low noise environment, but then again it certainly wont hurt.
The typical switching frequency is 600kHz, so the DSO Nano V2 wont give you much resolution on the switching waveform, but it will be better than nothing.
The circuit should still work with no load, but the device goes into its power saving mode so the output is just occasionally "pumped" to keep it at the required output voltage. That's going to make for a pretty nasty waveform that many multimeters will not measure very accurate. Adding a load resistor will put it in its normal operating mode and make a much flatter output waveform possible. On second thoughts, use a 33ohm 0.5W resistor to keep the output power down.
LightYear, thanks especially for the advice on the tantalum cap. 70 mOhm ESR caps are 1/3 the price!
-Russ
