Looking for ULTEM like material but more hydrophobic and conducting
I am looking for suggestions on a material that has similar mechanical characteristics to ULTEM. However, ULTEM is very hydrophilic for my application and not charge dissipating..There are some products form Solvay however, they are much more expensive than the Ketaspire. any suggestions?
ME
ME
RE: Looking for ULTEM like material but more hydrophobic and conducting
If the former plasma treat the surface with fluoropolymer or add UHMW silicone (www.mutibase.com) if it can withstand the processing temperature of the Ultem. If the latter that's more or less impossible but you can slow the ingress by using a barrier coating (e.g. www.inmat.com)
For charge dissipation you can use a conductive filler like metal flake / fiber, graphenes, MWCNT or other exotic solutions.
Chris DeArmitt - PhD FRSC CChem
Plastic & Additives Webinars
Instant Downloads & Inexpensive
www.plastictraining.com
It will not help you with static. Most anti-static coatings and additives (other than carbon black), work by absorbing moisture to increase surface conductivity.
I am not sure of the durability of Rainex, but it certainly works short term.
Both in combo might do the job.
DSM is the only supplier I know for sure who supplies SS filled materials, however I suspect, Ticona, Solvay, RTP Company and Sabic may do also.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Maybe it is a language thing, but I find your last post somewhat contradictory and confusing.
Pat
for site rules
Pat
for site rules
