IR cut film
IR cut film
IR cut film
Does anybody know of a supplier that makes plastic IR filter that transmit in 450-650 nm region and block IR radiation? The total thickness of the IR filter has to be 200 um. Thanks!
RE: IR cut film
We've had similar questions before. Did you search?
Chris DeArmitt - PhD FRSC CChem
Plastic & Additives Webinars
Instant Downloads & Inexpensive
www.plastictraining.com
RE: IR cut film
I did but couldn't find anything that was relevant to my case. Lots of IR coatings on glass, but absolutely no suppliers that make IR blocking filters on plastic..
RE: IR cut film
Most filters on plastic are organic, and tend to want to transmit IR.  You most likely need an interference filter, which is most easily deposited on glass
TTFN
RE: IR cut film
There are colourants for plastic that filter IR and transmit visable. It has been covered in detail several times before as it has also for UV.
Some of the IR threads where the opposite situation where they wanted IR transparency and visible opacity.
Certainly such dyes and pigments are available for certain laboratory glassware.
You need to contact suppliers of dyestuff and pigment. BASF, CIBA, Bayer all spring to mind. I am sure there have been mergers and name changes and new players from Asia, but you can search for that as easily as I can.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
RE: IR cut film
I asked BASF about this product
http://www.tvservice.basf.com/en/clip/category/automotive/topic/footage-on-the-concept-car-smart-forvision/clip/miwa-sashida.html
but they didn't get back to me yet, not sure if they have this commercially available. there must be some car window coating out there, but i don't think they will be as efficient in IR cut or not as we want a more sophisticated product with very clear cut-off ranges like transparency in 450-650 nm.
RE: IR cut film
Google "hot mirror" or "cold mirror".
