HELP on hydraulic system design
I have a hydraulic design problem.
There are two hydraulic pipelines, two pumps: one being driven by electric motor, the other by a human by peddling.
I need to join both the flows in one. Both pipes have non-return valves at the end.
The problem is, the pressure by electric motor pump is high(30 bars) and human peddling can't create that much pressure, so the non-return won't allow the flow to go through. Is there any way to increase the pressure or accumulate it(any device that could be helpful).
RE: HELP on hydraulic system design
Reduce the size of the human powered pump to allow human to be able to deliver against higher pressure.
Ted
is it feasible to let the human keep peddling and let the pressure increase to 30bar so that it pass through(though slow but it will work, right?)
You can either change the gear ratio on the bike or deliver less fluid from the pump.
i read about some, pressure booster on the net.
can that work?
You can use any sort of pressure intensifier that you can find. However, you seem to want a combination of pressure and flow.
For the amount of power available from the bike, you can have pressure, or you can have flow...you can't have both.
Without increasing the time, or reducing the flow, or dropping the pressure. The only way to get what you need is to increase the power available...that means get 2 bikes!!!
any other suggestions or changes on how to make it work?
Ted
You are trying to rewrite the laws of physics.
You can reverse the sprockets on the bike, you will be able to generate the pressure, but the flow rate of the pump will drop off. It would be like changing the gear ratio. Whoever pedals the bike would have to go really fast, but the pressure would be build slower.
The same amount of energy would be used, but over a longer time period...so the power would be less.
