ASTM property lookup - A182, F316Ti
I need the basic mechanical properties (YS, UTS, Elong., RofA, hardness) of this material from anyone with access to recent ASTM standards.
Thanks in advance.
Thanks in advance.
RE: ASTM property lookup - A182, F316Ti
30
75
30
40
N/A
Get yourself a Matweb account - useful and free!!
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Plymouth Tube
Europe is indeed the issue here. The only previous occasions when I have encountered this grade it has been in Germany (where I believe it has nuclear application). That said, I don't even know whether they would now use the German code or a European (EN) code to build pressure vessels.
The problem I have is obtaining a CRN for a fitting that by German rules is small and thus exempt from requiring design by their PV code. The largest component of the fitting is a 2"-150# F316Ti flange. I am not aware of any welds.
What I ultimately require is the allowable stresses for A182 F316Ti (as used in Europe) up to only about 600°F (300°C). Any guidance and web references for this would be much appreciated.
