Welding 4140 Q&T to 1026 Seamless Tube
We need to weld a premachined 4140 Q&T (131,000 psi yield) pin into a 1026 hrs seamless tube. The pin is shrunk fit into the tube before welding, and the weld is just a secondary means to assure the pin does not work loose or spin in the bore.
Since the 4140 is quenched and tempered and premachined for bearings, I don't think PWHT is plausible. In the past they have preheated to 400-450F and slow cooled and used E71T-1 wire. Is this acceptable? Sketch attached.
RE: Welding 4140 Q&T to 1026 Seamless Tube
