Dyna-material capable of negative plastic strains?
Is there a material model in LS-Dyna which can deal with plastic tangent moduli higher than the elastic young´s modulus?
An increase in material stiffness results in negative plastic true strains. Using it as input for MAT_24, negative plastic true strains are ignored and set to zero.
Can you propose a material model to me? Maybe a rubber-like one, as rubbers can also show an increase in stiffness.
Thanks a lot,
Maddog
