View boundary settings
Hello all,
where I can find setting for the view boundary offset from the part contours (see attached picture)?
NX7.0.1.7
win 7 64bit
NX7.0.1.7
win 7 64bit
RE: View boundary settings
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
If I change view boundary from automatic to manual rectangle, it does not changes according to model.
BTW, I never implied that 'Manual' boundaries WOULD update automatically.
John R. Baker, P.E.
Industry Sector
Cypress, CA
By the way: is there any setting to control this or not?
As to where this is set, just select the Drawing view of interest, press MB3 and select 'Boundary...'. The first time you do that you will see that it's set to 'Automatic Retangle', which is the default UNLESS you change it. If you select 'Manual Rectangle' you will be asked to select two diagonal points. If you set it back to 'Automatic Rectangle' and then select OK/Apply the view bounds will snap back to automatically include everything in the view.
I still haven't heard a good reason to be overly concerned about this since in the Automatic mode, the Drawing view bounds will always be close to being as small as possible.
John R. Baker, P.E.
Industry Sector
Cypress, CA
also i do not want to use manual boundary setting.
as you can see in the attached picture in my previous post, the view boundary is not close as possible (in horizontal direction). I believe, that there is a setting (i think I were able to find it some tome ago) to control this (as I remember it was a slider with %). but now I can not find this :/
John R. Baker, P.E.
Industry Sector
Cypress, CA
