Missing view boundary
I crated several circular detail views on my drawing and on one of them the Boundary circle has disappeared form the detail view. (it's still on the parent) Is there any way of getting it back without recreating (I have further children from the detail I'd rather not have to re-create)
I'm using NX 7.5
thanks
I'm using NX 7.5
thanks
RE: Missing view boundary
Format -> layer visible in view (click on view) -> make the layer that the circle is in (probably your work layer) as "visible"
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
Best regards,
Michaël.
Win 7 64 bit
Edit > view dependent edit
When you go into the expanded view and do a "fit"
Do you see the curve?
Try to change the boundry without seeing the curve, it may come back for you.
Unfortuately I already tried that one too. No dice the curve is just not there.
Technically, the glass is always full.
Delete the view and re create it.
unfortunately since the view has several child viewsa and was pretty much completed when I noticed it I would rather not do so this time.
