Variable Blend Radius
I have a slot punched through a thick solid body. On one end of the slot I need the edge to have a .13R blend while the other end is .38R. I have used variable radius points for blending before but when I try to use it on the slot it either changes it all to .13R or all to .38R. Any ideas on what I could be doing wrong? Thanks.
RE: Variable Blend Radius
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Maybe just supply the portion of the model that contains the slot. If you supply it without the blend then an unparametized solid would work find.
John R. Baker, P.E.
Industry Sector
Cypress, CA
