Weld Hardness / NACE MR0103 & MR0175
NACE MR 0175 states that hardness must be check on the PQR for carbon steel welding and should not exceed 22 HRC without PWHT. NACE MR 0103 states both value 22 HRC and 200HB and refers also to NACE RP 472 wich not define clearly a precise value.
How to be sure on which value we have to base the hardness test?
thanks
thanks
RE: Weld Hardness / NACE MR0103 & MR0175
MR0175 is for upstream oil and gas whilst MR0103 is for refineries. There should be no need to mix them up.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
