Hangers for systems in a concrete parking structure
I'm doing a dry system in a concrete parking structure. It is a two level structure and it is post tension slab on top of pillars. I'm curious what methods you all use for hangers for the pipes and sway bracing in such a scenario? Does anybody have any details that you could share? Thanks for the help.
RE: Hangers for systems in a concrete parking structure
Travis Mack
MFP Design, LLC
www.mfpdesign.com
http:/
I have seen situations where there was unistrut placed into the concrete prior to pour for the situation you described.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
Red heads work good for your 1/2" anchors.
Casting unistrut or J hooks into the slab is really only a guarantee your pipe will need to be somewhere else when it comes time to install. Concrete anchors give you flexibility so when the architect changes his or her mind you can actually get the job done.
