Tri-axle tractor trailer configuration
Greetings
I am looking to know the outside distance of of the two rails that a semi trailer frame sits on as the trailer frame is located onto the axle assembly. I would think that this would be a standard dimension since most axle sub assemblies can be bought as an outsourced sub assembly to the trailer manufacturers.
I would like to know specifically for the Tytal trailers if there is a fluctuation in the width dimension
I appreciate any reponses
Norbert
www.gdt-llc.com
http://
RE: Tri-axle tractor trailer configuration
