Reaction Force on the vent line of the Gas Injection system
Hi
Do someone have an idea in regards of the calculation of the Reaction force on the Chock valve placed on vente line system for the GI injection wells
Thanks for any feed back
RE: Reaction Force on the vent line of the Gas Injection system
ht
if you do not mind i think The question will more precise , since the API RP 520 is apllied for the Pressure safety Valve , Our Case is presented by a chock valve on the line , where it is Manualy Operated for discharging the line from his load. In point of view of the stress calculation can we assume the reaction force can be calculated based on the API RP 520 (Asumption that The chock is similar to the PSV ) ?
Good luck,
Latexman
From "BigInch's Extremely simple theory of everything."
could you precise the range of the small vent stipulated in your Reply ?
