Reuse Library
Reuse Library
Reuse Library
we are structuring our Reuse Library with one root name (Company name library) and under all type of library (standard parts, symbols, 2D sketches, features, etc..).
The problem is that NX show at the same level of our Reuse Library, also default NX library.
For example 2D sketch library is present at the same level of our library.
I set in the customer default the new 2D library path...but is still present in the Reuse Library resource.
I tried to remove, but NX say that is the defualt library and can't be removed.
Solution ?
This situation is on native mode, not TC managed.
Thank you...
Using NX 8 and TC8.3
