F8 as command button
it's possible to create a custom button that has the same behavior as the F8 keyboard ?
Thank you...
Using NX 8 and TC8.3
RE: F8 as command button
UG_VIEW_POPUP_SNAP_VIEW is the ug command, but i can't seem to use this in the button customization.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
I tried to use the UG_VIEW_POPUP_SNAP_VIEW as system command, but doesn't work.
With the macro work.
Thank you.
Thank you...
like:
BUTTON UG_VIEW_POPUP_SNAP_VIEW
LABEL snap view
BITMAP your c:\bitmap\snap view.bmp
thank you for your solution.
Thank you...
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
sorry for the delay.
I attach the toolbar that I created.
Nothing special, but useful.
Thank you...
I am running NX7 so it may have changed for NX8
If there is no visual clue that a command / feature exists, - how to i see that it's there ?
( don't get me wrong here, i love the snap view function, and the Shift+F8 in NX75)
John R. Baker, P.E.
Industry Sector
Cypress, CA
I noted that this specific command isn't visible in any menu or dialog and therefore can be difficult to find/ learn.
In comparison the "Shift+F8" is visible in the view popup when a sketch is active and also as a button ( default hidden) in the direct sketch toolbar.
I think the F8 is unique in this matter, at least i know of no other option that isn't contained in any dialog and only available as a keyboard shortcut.
I also follow the comments made on the various message boards about other CAD products including both our competitors as well as our 'sister' product Solid Edge. Just yesterday there was a comment made where a user had 'written' a program (and posted the results) to extract a list of the keyboard shortcuts, and their corresponding function names, used in Solid Edge. From the response he got it seems that this effort was met with appreciation. He also offered to update and republish the list with each new release of Solid Edge.
Anyway, I was 'shocked' to think that the only way that a Solid Edge user could get a comprehensive list of keyboard shortcuts was to 'write a program' which I assume parses the menu files to find all of the shortcuts when NX has a built-in option to show you that list anytime you want and which is always up-to-date, including any changes or additions that you've implemented yourself (I've been wondering how I would go about suggesting that perhaps the Solid Edge people should consider doing something similar to what we have in NX without looking like I was pointing out a shortcoming in their software as compared to ours ;-)
John R. Baker, P.E.
Industry Sector
Cypress, CA
I added "L" as Line, "C" as Circle, "F2" as Look at Sketch, and etc. in Sketch mode (access the above menu while in sketch and make sure "Use new shortcut in:" is set to "Application only") which was pretty easy.
The changes you make will show up on the Report print out that JohnRBaker described above
