Basics of Point Cloud
Hey all,
I am relatively new to NX (6-8 months) and am using NX7.
I am looking for a tutorial that could walk me through how to take a set of points and create a surface from them.
I have created a test surface using two splines and through curves and created a set of points equally spaced on it however every time I use point cloud the edges drop off and form a sharp point (ie. does not follow the set of points I created) and when I try to use "through points" NX tells me I don't have enough row/column degrees.
As a second question, if I had points extracted from a sphere, is there any way to recreate said sphere using the points as a starting point? (no pun intended!)
I've looked at the "Create Surface using Splines/Through Points?" topic @ http://www.eng-tips.com/viewthread.cfm?qid=151574 but wasn't able to follow most of what was said after the original post.
Jerry
Jerry
RE: Basics of Point Cloud
Insert -> Surface -> From Point Cloud...
...will always create a 4-sided surface, which means that it will also have 4 'corners'.
BTW, you also need to get off of NX 7.0 ASAP.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Jerry
John R. Baker, P.E.
Industry Sector
Cypress, CA
