Problem Making Cross Section to a STL filr
Hi, I was struggling with softwares in order to cut a STL file into a cross sectional view. I've tried to open with Solidwork, but I couldn't even work with the file through the software. I can't even select the surface. Anyone can help me?
Thanks!
RE: Problem Making Cross Section to a STL filr
After selecting Filef Type from dropdown list click the Options button that appears. This will give you an option to tell SolidWorks to import as a Surface or Solid Representation instead of the Graphics Representation that SolidWork selects automatically otherwise.
Sometimes if it's a really complex STL SolidWorks will just Puss (& Boots) Out and leave you stranded and Perplexed.
http://files.engineering.com/getfile.aspx?folder=ff5f5f5e-e54a-4175-a85a-0bf53d712b5e&file=SolidWorks_STL_chg-Graphics-Import-to_Surf-or-Solid.JPG
http://files.engineering.com/getfile.aspx?folder=e7723474-60a9-49b3-bab7-df666702c1ae&file=SolidWorks-STL_too-complex-for_Surf.Solid.import_error.JPG
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ Shweep
=   ProE       = SolidWorks
I'm still struggling with it. Thanks guys for the tips. I'll apply them next time i'm working on it.
