Slenderness Ratio for Seismic Zone
Does any can guide me on slender ratio min/max requirement limit in the sesmic areas.  With code reference will be highly appreciable.  Thanks
RE: Slenderness Ratio for Seismic Zone
Depends on the material and the element you are designing. Assuming you are using steel you need to reference AISC 341. All of the info should be in there.
