Help with distributed loads on a beam in mechanica
I was wondering if anyone knew how to put a distributed load on a beam in Mechanica?  I've figured out point loads, but can't for the life of me figure how to do a distributed load, nor has google or the search here been any help. Thanks.
RE: Help with distributed loads on a beam in mechanica
You have to create a curve which spans the area of interest (i.e. curve through points choosing two intermediate points) then select edges/curves as the geometry reference in the load definition box.
Hope that helps,
-J-
Oh and just an FYI there is a mechanica forum that others may monitor as well which may be a little more appropriate than in the general ProE forum.  There is generally a descent feedback there.
-J-
Here's The Link jvian mentioned.
I had it bookmarked already and you'll probably/have found it already.
PTC:CreoSimulate/Pro-E.Mechanica
For you non link trusters [Google Spell check=Trustees/Thrusters] out there,
Or if you like CTRL+Click or whatever Here ya go.
http://eng-tips.com/threadminder.cfm?pid=828
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ Shweep
=   ProE       = SolidWorks
