Catia - Need to remove a single surface.
Hi all,
How would one remove/split a single surface from a sheet of many surfaces that have been joined together?
I have been extracting, then creating a boundry, and then extruding the boundry so I can split to it.  A long process just to fix a surface that does not pass the boundry test.  Heeling did not seem to resolve the sheet issues.
Jim
RE: Catia - Need to remove a single surface.
Use Extract with point or tangent propagation and turn on "complementary mode"... works like a charm but remember to hide previous join operation afterwards.
Azrael Thank you,
It worked great with No Propagation though.
Jim
