Visual Basic, Logic Problem
I know the problem in here has to be the logic, but for the life of me I can't find it.  Any help would be appreciated.
CODE
strSValue = "s" & svalue             'Set strSValue to s#
      strSValue2 = "s" & svalue & "="      'Set strSvalue2 to s#=
      strExpFile = "expressions test.exp"
      OpenFile( strDir, strExpFile )
      line = sr.ReadLine()
      '    While the file still has lines continue with if statements to compare lines with Strings
      while Not line is Nothing
         '     Ensure before comparison that the line is not empty
         If Len( line ) > 2
            '     Take the read line from the file, and set strExp equal to the string starting at the
            '         fourth character and reading the following 3
            strExp = line.substring( 4, 3 )
            '     Check that the value of strExp equals strSValue (s#) or strSValue(s#=)
            '         if yes, increment # and reset the string values exit if statement
            If ( strExp = strSValue or strExp = strSvalue2 ) Then
               sValue = sValue + 1
               strSValue2 = strSValue & "="
         'ElseIf strExp = strSvalue2 Then
            'sValue = sValue + 1
            'strSValue = "s" & sValue
            'strSValue2 = strSValue & sValue
            End If
         End If
         '     Read next line of file and return to beginning of while statement
         line = sr.readline()
      End while
I am trying to read a file that looks as follows, but I only want to know how many s# values there are, I do not wish to count the s#_chord etc.
[degrees]Tool=11.00
[mm]BladeLength=26475.00
[mm]BladeDef=1450.00
[mm]S1=0.00
[mm]S2=700.00
[mm]S3=6135.00
[mm]S4=7485.00
[mm]S5=10185.00
[mm]S6=12885.00
[mm]S7=15585.00
[mm]S8=18285.00
[mm]S9=20985.00
[mm]S10=23685.00
[mm]S11=24765.00
[mm]S12=25305.00
[mm]S13=25845.00
[mm]S14=26115.00
[mm]S15=26385.00
[mm]S16=26475.00
[mm]S1_Chord=1250.00
[mm]S2_Chord=1250.00
Again I appreciate any help.
RE: Visual Basic, Logic Problem
This is the type of problem that regular expressions excel at. This site on regular expressions was (and is) a great help to me. Below is a quick example journal based on your data. I used an arraylist for testing, just take the important bits and integrate it into your file read loop.
CODE
Option Strict Off
Imports System
Imports System.Collections
Imports System.Text.RegularExpressions
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim lw As ListingWindow = theSession.ListingWindow
Dim i as Integer = 0
Dim myValueList as New ArrayList()
myValueList.Add("[degrees]Tool=11.00")
myValueList.Add("[mm]BladeLength=26475.00")
myValueList.Add("[mm]BladeDef=1450.00")
myValueList.Add("[mm]S1=0.00")
myValueList.Add("[mm]S2=700.00")
myValueList.Add("[mm]S3=6135.00")
myValueList.Add("[mm]S4=7485.00")
myValueList.Add("[mm]S5=10185.00")
myValueList.Add("[mm]S6=12885.00")
myValueList.Add("[mm]S7=15585.00")
myValueList.Add("[mm]S8=18285.00")
myValueList.Add("[mm]S9=20985.00")
myValueList.Add("[mm]S10=23685.00")
myValueList.Add("[mm]S11=24765.00")
myValueList.Add("[mm]S12=25305.00")
myValueList.Add("[mm]S13=25845.00")
myValueList.Add("[mm]S14=26115.00")
myValueList.Add("[mm]S15=26385.00")
myValueList.Add("[mm]S16=26475.00")
myValueList.Add("[mm]S1_Chord=1250.00")
myValueList.Add("[mm]S2_Chord=1250.00")
'the pattern is set to look for S
'  followed by 1 or more digits (\d+),
'  followed by =
Dim re as New RegEx("S\d+=")
lw.Open
For Each myExp as String in myValueList
    if re.IsMatch(myExp) then
        i += 1
    end if
Next
lw.WriteLine(i.ToString & " items matched the specified regular expression")
lw.Close
End Sub
End Module
www.nxjournaling.com
You might want to visit Tek-Tips, a sister to this site where the computer geeks live and hang out..
I ended up stumbling across this and it worked with the current program.
Dim douExp  As double = val(line.substring(5))
It skipped the [mm]s of each line and read until it came to a non number value, which made things quite a bit simpler.
Posted just in case this is looked at by a person needing help in the future.
Thanks for the tip Mike, I'll check that site out.
Why don't you change this line
CODE
to
CODE
If ( strExp = strSvalue2 ) Then
