Teamcenter Import with Auto Naming
I have an assembly that I'm working on locally in NX7.5 that I want to import into Teamcenter. If I go into each part, and select Properties and go to the General tab, each part has a unique Name associated to the Part Number. I know that when I import the assembly into Teamcenter, it will automatically know the correct Part Number, but is there also a way to import this Part Name as well? Thanks
RE: Teamcenter Import with Auto Naming
Either way you should be able to set the DB_PART_NAME attribute with a value the same as the Part Name you already have, then when you import this saved part into Teamcenter the DB_PART_NAME attribute translates to the Item Name in Teamcenter.
If you want a bit more on attributes search this forum for DB_PART_NAME and you'll find plenty of threads discussing them, which may enable you to find the right section in the help documentation.
