Stp file software origin
Is there any way of finding out in which software a stp file was originally created?
I am using Pro/E WF 3.0.
RE: Stp file software origin
If the originator has their config set up correctly, the information window should display their name, the date of origin and the system that was used to make the model.
Ben Loosli
Thanks a lot for the info.
I tried what you suggested......Works for (at least) stp files created by solidworks and ProE.
Thanks again :D
