Clay with cobbles
Clay with cobbles
Clay with cobbles
Hi all,
Do you know if there is any way I can simulate clay with cobbles soil on plaxis or any other program?
Thank you in advance!
RE: Clay with cobbles
What are you trying to model?  For most gravelly or cobble-filled clay soils with more than 5-15% clay, the cobbles do not impact the strength or angle of internal friction.  The cohesive strength of clay controls since there is no rock-rock interfacing.  For simple settlement or capacity calculations ignore the cobbles, and use a standard M-C model.  Will that work for what you are doing?
