stairs - concreting section - where is stop?
Hi guys
I got suspeect few times when i saw the concreting sections on the site. See here on of the photos. Can this be right?
The new section will basicaly act only as share fors on the bars. This doesn't look to correct?
What is the right way to do it?
i attached some samples sketches maybe you could give a comment on it.
buy
Adi
buy
Adi
RE: stairs - concreting section - where is stop?
One thing you can do is roughen the surface of the concrete with a chipping hammer to get a higher friction across the joint.
I get the impression you are not from the US (from the language on the photo) so the ACI 318 code may not be applicable (its Chapter 11 Shear Friction provisions are the applicable section).
The others just don't look right if the right hand landing is hanging from the left hand stair structure.
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
I took it that the stair was bearing on the landing/floor, not the other way around. The landing and flights are normally cast between previously built floors.
Fortunately.
