BLF safety factors with real world problems.
When calculating buckling load factors with FEA programs such as Pro/Mechanica what type of safety factors do you guys use for real world problems? e.g. Thin walled cantilevered beam under static bending loads.
I understand FEA does not consider real world manufacturing inaccuracies etc. Hence the question.
Are there any codes or standards that cover this?
RE: BLF safety factors with real world problems.
The lower factor is more relevant for the short/intermediate column range where plasticity (Johnson part of the Johnson-Euler curve) is often slightly conservative compared to empirical data.
A FEM could account for the real world scenarios (manufacturing tolerances, imperfections, eccentricities, etc.), but only if you tell it to. But because it is not usually practical (nor are the scenarios always easy to quantify), we often just solve the nominal solution and apply a margin of safety based on empirical data.
Brian
www.espcomposites.com
For structural work this is codified in Eurocode EN1993-1-1 and similar codes. In simplistic terms the buckling load factor is back calculated to give a slenderness ratio which is then applied to the strut curves that include allowances for initial imperfections and residual stresses. There is no one simple additional factor that can be applied and the final design load factor in structural work can often be many times less than that obtained from an Eigenvalue buckling analysis.
As you say permissible stress design will give you a slenderness ratio that can be compared to allowables that incorporate allowances. Limit state will use the elastic buckling load factor to calculate a moment amplification factor. Both of which are not useful in numerical analysis and so a suitable BLF must be selected.
I don't know of many structural codes that give BLF for FEA. There aren't many that even cover FEA with allowables for local stresses, and classification of primary and secondary stresses. When modelling a structure in FEA generally the imperfections in material and manufacturing are not modelled or able to be modelled so this must be included in the BLF. Unfortunately a lot of this comes down to engineering judgement without specific design codes.
