Effective permittivity
Suppose you place an antenna at x=-d in material with permittivity e1. At x=0 the permittivity changes to e2 while the space is homogenious in y- and z-direction. In material with permittivity (relative) e>1 the wavelenght is shorter than in free space causing the resonance of an fixed size antenna to move down. My question is how one could predict this frequency shift as a function of d, e1, e2, conductivity and the type of near-field the antenna has? From this change of frequency we can define the effective permittivity of the point. Any relevant literature on this subject?
RE: Effective permittivity
Distance is a term of attenuation, not frequency.
Conductivity is a term of Q and bandwidth.
Near field is a subject of another order that is beyond my answer at this point.
Here is an answer on how to predict frequency resonance of a fixed size antenna:
It is the frequency of the length contraction to half the physical dimension of the fixed size antenna given by the Einstein-Lorentz Transform.
The permittivity and permeability at the resonant frequency are modeled as the capacitance and inductance respectively of an equivalent resonant circuit with the impedance equal to the free space impedance.
Subjects of relevant literature will discuss forshortening effects at relativistic velocities and the permittivity and permeability come from resonant circuit calculations. The details are left to ojniemin. I have yet to find a written example of the method done by anyone other than myself; it is too lengthy to elaborate here and I do not have an example prepared, but you will get the idea, since you asked.
As far as conductivity is concerned you might be right. What comes to d, e1, e2 I still say that they affect the resonance frequency of the antenna. You see this practically just putting your hand on an antenna tuned for 900 MHz, for example, and looking at the resonance. The resonance will go down in frequency and the return loss will get much worse. The former due to the permittivity and the latter due to the conductivity of your hand.
I suppose it is hard to formulate any analythical (or empirical) relation between the resonance frequency and the mentioned parameters because the type of the near-field complicates it all. For example, a patch antenna with high dielectric constant 'binds' the electric field close to the antenna, and is therefore not so sensitive to external dielectric material close to the antenna. Some other types of antennas with different characteristics are much more sensitive.
The same is with putting some dielectric on Your antenna. I don't remember formulas but there should be some equation. Even at design of protecting surface for patch antennas producers are using materials with epsilon close to 1 to support open space conditions. Thickness is quite important at such designs.
But in my opinnion such solution has th biggest influence on the radiation characteristic.
http://www.ee.cityu.edu.hk/~eekleung/paper_download/mtt_mar01.pdf
http://www.geuz.org/publis/00.compumag99.geuzaine.MWFEMTD.pdf
http://www.ece.uvic.ca/~jbornema/Journals/068-98ap-gb.pdf
http://wes.feec.vutbr.cz/~raida/multimedia_en/chapter-4/index.html.en.iso-8859-1
etc. for more info (notice that the permittivity is a tensor)
