NX6 freezes in edit excel familie sheet
when im trying to edit the familie sheet from Tools -> Part Families and 'edit', it freezes:
when i click on edit, NX6 turnes grey, as in im in excel, but excel doesn't show.. then i have to shut it down with task manager.
is this is a common problem or does anyone know the solution?
kind regards, Chevy
RE: NX6 freezes in edit excel familie sheet
What version of Excel are you using?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
2010, I can use the add in if i create them but I can't edit them..
Can you provide a snippet from your logfile? If you cant save them via the help menu, you can find it in your temp folder.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
[i use 64 bit system for extra information]
Can i still find it when it shuts down? how do i find it in the temp folder? what name does it have?
username+random number . syslog
just sort the files in c:\temp on Date modified on it should be on top.
Look into the file with notepad and just save as the last lines of the log file, you will see when the error is occurring.
If you are working with Teamcenter you will also see tc.... .syslog don't need that one.
Best regards,
Michaël.
Win 7 64 bit
i wish there was.. last one was made a month ago and its not like that. i happened yesterday..
You can check where the log file is situated, open nx, open a part, go to Help menu, open nx log file on the top of the file you will see ***c c:\temp\username+randomnumber.syslog
It's possible that the logfile is in c:\user\localsettings\.....
Best regards,
Michaël.
Win 7 64 bit
nevermind..
my apologies!
the edit sheet just took a really long time to load..
thnx for your help though!
