Contacting or non-contacting backup seals...(wet or dry)
thread819-293637: What is the best back up seal for LPG service
In continuation to a previous discussion....
There are other factors in play but if your product is one that leaves a residue when it dries, and your primary seal is a pusher, then you are best served by using a contacting WET seal as the backup seal. My two centavos.
Jose Jalapeño ( on a stick)
RE: Contacting or non-contacting backup seals...(wet or dry)
Can you send us some information on the process condition? It would be good to see the product SG, suction and discharge pressure, VP, temp, shaft size?
If you have a pusher seal and the product leaves a residue, you may suffer from hang up as the residue builds up under the dynamic oring. You must avoid this at all costs as you will experience pre mature failures. Are you sure the residue is not carbon face wear? If you have high VP and low SG then you may experience this synario.
If you Are using a single seal and having good seal life and want to improve seal life then a liquid Tandem seal may prevent the residue build up and increase seal life!
Sendg some more detail and any pics of what you have to assist us in assessing your concern.
