Nastran non linear analysis help
I want to solve an autoclave component in nastran using sol 106(Non linear static). I have modeled the component using Hex20 elements.But whenever I put it to solve, it will complete in about 5 seconds and the f06 file will be 0 bytes. But if I model using hex 8 elements, it is solving. So can anyone please tell me what might be the error?
Bharat
RE: Nastran non linear analysis help
BTW, I modeled the component using Hypermesh 10, sorry I forgot to mention it in the question.
Hello!,
Look for fatal word in the *.f06 nastran output file, there you will see the reason of the error.
For instance, if you run NX NASTRAN take in mind the following:
• Linear CHEXA 8-nodes: can be used for Nonlinear Elastic, Elasto- Plastic and Geometric Nonlinear Analysis – Small Strain Elements.
• Parabolid CHEXA 20-nodes: The higher order elements can be used only for Nonlinear Analysis — Fully Nonlinear (Finite Deformation) Hyperelastic Elements, including large strain and large rotation.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
