turning on Datums while in assy contraints
Hey all. So when applying assembly contraints to a part in an assembly in NX 6 I sometimes find the need to turn on datum planes in the part I am placing so I can finish the constraints. To do so now, I have to close out of assembly contraints, go to the part in the navigator and change the reference set to "entire part" to be able to see the planes in the assy. Then I can go back to the constraints and use the planes for mating, aligning, etc. Then when finished, I have to go back and change the reference set of the part back to "model" for example. Is there another way to access datum planes while in context of assembly constraints that makes more sense?
thanks
thanks
RE: turning on Datums while in assy contraints
If you're really going to be using a lot of Datum Planes you may wish to at least add the critical Datum Planes to the Model Reference Set and then use the Show & Hide... function to quickly toggle ON/OFF the display of the Datums.
Or you could do as you're doing now, by replacing the 'Model' Reference Set with 'Entire Part' except that instead of setting it back to 'Model', just use the Show & Hide... to manage the display of the Datums until you're ready to save you assembly at the end of your sessions where you could set the Reference Sets back to 'Model' and then save.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
The keyboard shortcut is "CTRL + W". It's super fast to flip between the 2 states.
I pretty much leave everything hidden until I need it.
When I need it I just "Show All" the datums, apply what I need and then hide everything again.
Nice workflow for me.
J
NX 6.0.5.3
John R. Baker, P.E.
Industry Sector
Cypress, CA
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
I always constrain parts dragged from the library using their datum planes, but the reference set is set to Model for parts from the Library, therefore I need to manually change the reference set to Entire Part EVERY TIME I place a component in order to see the datum planes.
Is there a way to permanently set the reference set to Entire Part when dragging a part from the Library? And for every session?
