Exporting a SINGLE Jt file using NX6
I was asked to do a task at work involving exporting a single jt file. I was instructed, and followed up by internet, that by choosing "As a Single File" under the JT preferences before exporting, would give me one JT file. Instead I seem to get the same result as if I had never changed the setting even though I am making sure to save the configuration and go back into it to make sure it has stayed on my saved configuration. I get the file that I want but also a folder containing all the parts within the assembly. If the folder and contents are deleted or moved away from the single file, the components will not open in the JT2Go. Any tips or suggestions?
RE: Exporting a SINGLE Jt file using NX6
Use the search button a little under the title of this forum and eneter "jt file" as the keyword - there's probably something there that will help you out
I just tested in NX6 and it works when I did the following:
1. Preferences -> JT, set to As Single File. then click OK.
2. Click on save configuration and specify a new file name for the config file. Then make sure that file is listed as the config file you are using.
3. Then click OK.
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.4.4, NX8.0.0.25
