antenna tower surface prep: cost vs benefit
hello folks,
I have a ~90' galvanized/painted antenna tower that is quite old and is in need of repainting. The existing paint is chipping and there are some rust spots that need to be taken care of. My question is, what is the cost vs benefit of sandblasting or similar vs hand tools/manual labor to prep the surface for repainting? Environmental issues are a concern so I imagine the tower would need to be covered completely prior to any blasting which would create even more expense. I am assuming that blasting the tower would be the most effective but most expensive option for prep and hand tools/labor would be less effective but less expensive. Can anyone chime in on this or help guide me a little to a next step? I suppose I could/should call and obtain rough estimates for each alternative from several reputable businesses.
RE: antenna tower surface prep: cost vs benefit
http://w
