PTS + routing as editable pipe net
can you help me to find some informations/guides how to use product template studio with pipes/profiles that make complicated line nyetwork? net is similar complexity like tower crane body (vertical part of tower crane) pipes/profiles have to be editable (if needed i have to change shape of cross section of profile), and all net have to be editable so i can change number of segments and distance between segments (that is why i use PTS).
if this is not clear enough i will provide more informations.
RE: PTS + routing as editable pipe net
All I can say is this: PTS is not a magic tool that can creat the 3D model for you...I worked on the PTS just a little. Basicly you have to model all scenarios in NX first(make sure your model is SUPPER ROBUST because you will use the NX expessions to turn on and off your model) then you use PTS just as an friendly interface so that end users can easily change the number of segments or distance...etc..
