MAVR BRUSH old units
thread237-268013: Self-excited generator
any body know a source to repair a old MAVR for brush bdax units
regards
amper
regards
amper
RE: MAVR BRUSH old units
The MAVR is a pretty straightforward piece of equipment - we used to repair ours ourselves. I likely have the circuit diagram and probably a component list stashed somewhere, perhaps even a description of how it works if you're lucky. Our AVR variant had a very high power rectfier to provide field forcing, much larger than the standard MAVR which was good for a handful of amps. The control stages were pretty much identical as I recall.
Do you know which part has failed?
do you roper can mended it this pice equipment? , they are very realibale , i imaging using the primic can be headake both pocket very pricely , as well maybe not to good as this old analogic old mavr
brush dont ofer more support/spare for this unit , option from them is emigrate to prismic or other units with other acronims
rmw
