Corrosion resistant stainless steel
We used 304 stainless steel sheet ( 3mm thick punched with holes ) as air filter plate in a locomotive. Rust is seen on the sheet with time.What is the best economical grade for this use?
RE: Corrosion resistant stainless steel
Passivation after forming would eliminate this.
What is the max operating temp?
As long as it is under 600F you might look at using 2205. It is close to the same price as 316 and is much stronger and has much higher corrosion resistance.
Plymouth Tube
You need to define the environment and the form of corrosion better before considering a material upgrade. There is not usually a silver bullet solution to corrosion, and sometimes less is more (man am I thick with clichés today).
While I do not disagree at all with your assessment of the paper industry, I find it hard to make the leap from locomotive air cleaners to the stench of a paper mill. Help me make that trip?
rmw
The rust around the fasteners makes me suspect that they are plain steel.
Does it clean off? Use a flap wheel and see what it looks like underneath. If there isn't any pitting then it is all superficial and should clean up.
No, passivation isn't hard. Warm nitric acid for an hour, or hot citric acid for 12 hours.
Plymouth Tube
Bob
