greassing ball valve
hi
is there a specific type of grease for the lubrication of ball valves?
thanks
thanks
RE: greassing ball valve
See my comments to the posting 'valvesealants' below.
BEFORE undertaking any greasing of ball valves - contact the manufacturer for their recommendations. In general, for ball valves: if it is working OK, leave it alone.
I do absolutely agree PeterIgg, good point! Hope this also is (somewhat?) obvious from my answer!
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
.. godel123, I do not believe we are talking about the gearbox. Even at that many gearboxes (mechanical gearboxes) are greased for life, pneumatic only lightly greased or non-greased, electrical usually not or exceptionally at given points at given intervals.
As for grease type if required: as given in the gearbox manual.
Best regards,
VRF
