Import file - broken
After instaling update 8.0.1.5, command "file/import/part" in drafting does not work correctly.I use this comand for insert titleblock in drawing. See image. My titleblock is broken. Before update was ok.
File with titleblock is also ok.
NX 8.0.0.25 MP1
RE: Import file - broken
I reported a bug for a customer in NX8.0.1 that when you import a part file (with their titleblock) the annotations are in the right position, but can't be seen. A regenerate work is the workaorund we found.
I haven't seen your problem in testing for that one, but if you can replicate it, send it off to GTAC.
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.4.4, NX8.0.0.25
What to do? I have to downgrade again to version 8.0.0.25?
NX 8.0.1.5
Are you able to send me the part you are importing? (the one with the title block). I have NX8.0.0 and NX8.0.1 installed so I can check in both.
Anthony Galante
The problem is not NX8.0.1. The titleblock imports into NX8.0.0 the same as in NX8.0.1.
Your titleblock is on the negative X (see the attached image showing the block in NX8.0.0 and the position of the titleblock).
Move the titleblock to the right position save the file and then when you import it will be OK.
Anthony Galante
In version 8.0.0.25 is so ok. After import part, select bottom right corner of border. Titleblock is after in right position and anotation is in "0" position.
NX 8.0.1.5
OK, when I do it like you've said, the titleblock is in the right place, in NX8.0.1 but the annotations are off the sheet on the left.
That doesn't happen in NX8.0.0.
Report it to GTAC is all I can offer.
Anthony Galante
