NX 7.5 Tube pulls Blend
I have attached a jgp of a what I have modeled in I-Deas on the right and the same tube I modeled in NX on the left. These two tubes meet on a compound angles. What would be the appropriate way to model the Blue Surface in NX. A fillet will not work becuase it goes all around the edge. When we used the CMM to import this part into NX this area failed. I have tried bridge curves and mesh of curves but I am not that strong in this area yet. Thanks for the help.
RE: NX 7.5 Tube pulls Blend
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Another solution provided here.
Sadly i had to subdivide the section curves ( tube / datumplane) and that killed the associativity. - The starting points of the curves did not match and i didn't have the power to play around with the "Alignment by Points method.
The Thru curves feature does not like if the sections become tangent to each other.
