Multi-body part scale
I inserted a part into a part.
Then I added a scale.
It does not scale the inserted part, only the active part features.
Is there a way to scale this part?
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
RE: Multi-body part scale
Depending on the end requirements there are several alternatives...
Apply the scale to a config of the original part, and then Insert > Part.
-or-
Make a copy of the original part, apply the scale, then Insert > Part.
-or-
Create a set of offset surfaces from the original.
You can use the SW Scale function or Lenny's ModelRescaler macro at http://www.lennyworks.com/solidworks/default.asp?ID=20.
Thanks.
It looks like the part I used is a series of sketches used for top down.
The scale function will not work with the model because there are no features other than sketches. I tried making config's then scaling the sketches, but it threw up on other models using the part with sketches.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
I haven't used Lennys ModelRescaler macro on a sketch, but it may be wort trying because it works on the dimensions, not the geometry.
Just ran a test. The macro works fine on dimensioned sketches.
