Compressor and Motor Shaft Elevations
This is about compressor and its motor shaft alignments.
Usually compressor manufacturers put motor and compressor shafts in the same horizontal elevations, is there any specific reason for that?
If the motor's shaft is higher or lower, still its alignment with compressor's shaft can lie in a flat plane. So apparently putting both shafts at the same elevation is not a necessary requirement. Am I right?
RE: Compressor and Motor Shaft Elevations
There may be some opprotunity to move the motor vertically up after initial installation before coupling during alignment, but that is limited. And building a platform under each foot can be a bad thing.
Sorry if I misunderstood the question.
(2B)+(2B)' ?
Mike Halloran
Pembroke Pines, FL, USA
That is the axis of both shafts have to line on the same line.
That is all that is necessary.
One problem with having both shafts at the same nominal height to start is that you could have to shim either part, so you need shims to fit both. Whereas, if they were different nominal heights, you'd only need to shim one, so you prepare one set of shims.
If you're lucky, at least you have one sturdy planar surface to wrestle the components around on, so all the shims can be the same.
Mike Halloran
If you have anything but a "perfectly aligned" flange-flange connection between the shafts, your customers are going to get another supplier. So nobody builds them any other way.
I think we are talking about motors and compressors with flat(ish) bases, aligned for direct drive, which IMHO is not a super great idea absent a radially and angularly compliant coupling.
Agreed that belts and gears can be a maintenance headache. In the common circumstance, they are used between e.g. a two-pole motor and a load that can't be driven that fast, in order to save weight and/or cost over a lower speed motor. One also has to be careful when ordering a motor, because generic motors usually come with bearings that are not rated for any substantial radial load.
Mike Halloran
The alignment is accomplished using laser equipment capable of meeting the required tolerance. In our facility, we would normally expect the alignment to be within 0.002" of the target in both the vertical and horizontal planes. The targets are based on the expected movements of the machines in the running condition. For a typical API centrifugal compressor, the OEM would provide the alignment targets. Even though the compressor is supported by feet at the elevation of the shaft centerline, some amount of growth is unavoidable. Yesterday, we completed the alignment of a 4000 HP, 9000 rpm Coker wet gas compressor. The train consists of a motor, gear increaser and compressor. The targets called for the motor to be set 0.010" higher than the gearbox and 0.006" to the East. This allows for the fact that the gearbox will grow much more in the vertical direction than the motor. The horizontal offset allows for the spread of the gears at full speed and load.
The targets for compressor alignment required that the compressor be set 0.015" higher at the inboard support feet and 0.006" higher at the outboard feet. The compressor was to be set 0.004" to the West. The difference in vertical offset on the two ends of the compressor allowed for the different temperatures primarily driven by the heat of compression. The outboard end was the discharge end which runs much hotter than the inlet end.
For machines with no gearbox, the alignment targets usually only require a vertical offset. Both the motor and compressor would be designed to grow straight up, with very little horizontal movement.
Even with an alignment tolerance of 0.002", a flexible coupling is needed. It would be impractical to achieve and maintain an alignment precise enough to allow for a rigid flange coupling. Without the flexible coupling, the shaft would fail from high cycle fatigue in bending. Coupling manufacturers will brag about the capability of their flexible coupling to accommodate misalignment. But, no matter what the supposed capability of the coupling, a precise alignment will reduce the loads on the bearings, seals, gears and other components. A precise alignment will result in lower vibration levels and increased reliability.
Johnny Pellin
I've seen this done too, by some manufacturers. I've also seen plenty of belt-driven equipment where the two shafts are at different elevations.
I'm curious too: is there some physics involved, or does this make alignment of the shafts/sheaves easier, or is this purely an aesthetic thing?
Your interpretation sounds reasonable to me, atlhough op should be the one to clarify.
We have plenty of belt-driven fan shafts at different elevation than motor shaft. I'm sure there is no problem with that as long as equipment and support including tensioning arrangement is designed for it.
I can think of one possible reason some designers might prefer the same horizontal level: the belt tensioning device typically moves horizontally. If the belt were 45 degrees from horizontal, then the force applied by belt tensioning screws in horizontal direction must be sqrt(2) higher than if belt were horizontal. I doubt that's a big problem but it's the only thing I can come up with.
(2B)+(2B)' ?
